Hi Pranav,
Not sure I understood the request, but in Flux you can measure the flux density where you want thanks to point sensors, or by creating a path.
Best regards
Hi Pranav, Not sure I understood the request, but in Flux you can measure the flux density where you want thanks to point sensors, or by creating a path. Best regards
Hello Farid,
Thank you for your response.
Basically, I am able to plot the flux density on the rotor surface using the sensors but that wave form is in the stator reference frame.
Hello Pranav;
The plot of a given quantity is always given on the global coordinate system XYZ. You can modify if you want the coordinate thanks to VLSC() feature.
If i inderstood well, you want to have a flux density (spatial distribution) and temporal distribution (vs time or rotor position)?
If yes, the best way to do it, is to make a path in the air gap, and plot a 3D curve on the path, this allow you to have temporal (rotor position) and spatial shape of the flux density in the airgap.
Or more if you want, you can use a 3D curve dedicated for rotating machine, it will make the same thing with few settings.
I hope this will help you
Hello Pranav; The plot of a given quantity is always given on the global coordinate system XYZ. You can modify if you want the coordinate thanks to VLSC() feature. If i inderstood well, you want to have a flux density (spatial distribution) and temporal distribution (vs time or rotor position)? If yes, the best way to do it, is to make a path in the air gap, and plot a 3D curve on the path, this allow you to have temporal (rotor position) and spatial shape of the flux density in the airgap. Or more if you want, you can use a 3D curve dedicated for rotating machine, it will make the same thing with few settings. I hope this will help you Best regards
Thank you again for your reply. I am actually trying to measure the flux density on a point located on the rotor surface. And I am looking for the changes in flux density on that particular point as the rotor completes one revolution.
I tried using the 3D curve dedicated for the rotating machine, and I am receiving error. I guess one of the reasons could be that the model is completely build in 2D..?
