I have a pipe delimited Text file that varies in length. I need to create a model for it to extract the data into an excel file. But the | in Monarch classic appears to be used for numeric or a trap. I have been unsuccessful in figuring out how to create the model as a floating Trap.
I would normally just use Monarch complete when opening a Pipe Delimited file but I need a model that can be used in the content server on the report/Document. So far I have not found a way to use a 'workspace' on a file within the content server. it appears it must be a 'Model' that is used.
Has anyone else come across this issue and found a solution?
here is an example of the file:
RECORD TYPE|PROCESS DATE|PAYEE|SELLER SERVICER|INV|CAT|LOAN NO|INV LOAN NO|ACTIVITY|EXCEPTION CD|LLR SUB IND|ADJUSTMENT AMT|FILE ID|
LOAN|10/27/2020|01H01|156236|H01|001|9999999999|075658444013|DAILY LIQ|61|N|.37|7777|
LOAN|10/27/2020|01H01|156236|H01|001|4444444444|32586429|DAILY LIQ|61|N|.84|7777|
LOAN|10/27/2020|01H01|156236|H01|001|7777777777|66551738|DAILY LIQ|61|N|.96|7777|
EOF||||||||||||3149|
Thank you!
Melissa Falardeau
Melissa Falardeau
Solutions Analyst
AmeriFirst Financial Corporation
Portage MI
(800) 466-5626 Ext # 10318
