Good morning,
While preparing the CFD simulation recently I noticed the issue with launching the calculations, because of the software being unable to locate the ''Boundary Condition file.''
It happened in the simulation, where I had a manifold with 4 separate chambers. This is why I treated them as 4 separate solutions within one SimLab database. To have all the data clean and under easy control I kept naming all the bodies, meshes and boundary condition and I noticed problem with the last step here.
When I tried to name the inlets and outlets I was receiving error at the beginning of the simulation:
acuPrep: ***ERROR: unable to open file SIMLAB.DIR/Outlet_noDCDC_side.FluidbodyOutletnoDCDCside.tet4.Surface_3638.tria3.ebc; file Outlet_noDCDC_side.inp line 226; at or before: G } F
acuPrep: ***ERROR: SURFACE_SET( "Surface_3638_FluidbodyOutletnoDCDCside_tet_tria3" ) {
acuPrep: ***ERROR: surfaces = Read( "SIMLAB.DIR/Outlet_noDCDC_side.FluidbodyOutletnoDCDCside.tet4.Surface_3638.tria3.ebc" )
acuPrep: ***ERROR: ^
But when I kept the same mesh, same parameter's values of inlet and outlet flow, but I did not rename the boundary conditions (I kept generic names) the simulation has run smoothly:
Is there some guideline for naming of the components within the simulation to avoid such a problems? Or is it some known problem, which is planned to be solved?
Thank you in advance.
Best regards,
Michal
