I am learning OSSmooth, but I dot get the *.grid file when solving the optimization problem. How can I generate the grid file?
The .grid file is only generated when topography or shape optimization is performed.
You can find more information on the *.grid output file in the OptiStruct documentation @ https://help.altair.com/hwsolvers/os/topics/solvers/os/grid_file_2.htm
Details on running a topography optimization can be found @ https://help.altair.com/hwsolvers/os/topics/solvers/os/topography_opt_intro_c.htm#topography_opt_intro_c
Details on running a shape optimization can be found @ https://help.altair.com/hwsolvers/os/topics/solvers/os/shape_opt_intro_c.htm#shape_opt_intro_c
Greg.
Thanks Greg. If I run topology by OSSmooth using version 2021.2, I don't have to define *.grid file, only *.sh file. However, if I use HW 2022.3 I don't see *.sh file request, only the *.grid file. How can I run the OSSmooth for topology in 2022.3?
