Hi all,
I have some questions about generating a homogenous dense packing, where the solid concentration is very high (over 65%) thus the overlaps between particles are hard to avoid. My simulation contains two different size of particles and the size ratio is about 5. When I try to generate such dense particle packing with "volume packing" and change the value of "Remove particle overlap" to a relative high value. I found the number of smaller particles is much lower than my expectation. I guess some small particles are generated inside large particles as the tolerance of particle overlap is actually larger than the diameter of small particles. I haven't found an efficient way to generate such dense(volume fraction over jamming point), binary(size ratio are large), homogenous packing.
Anyone can give some possible solutions for this case?
Best regards,
Yang
