I've been trying to use the same model to obtain a 1T field at varying frequencies using a steady state ac model. I have iterated the current through a coil until the magnetic flux density averages 1T through the parts cross section, then changed the frequency and repeated.
I'm getting an anomaly that at low frequency, it requires more current to obtain the same magnetic flux. See results below:
| Frequency | Current | Mag Flux (T) |
| 5 | 5.5 | 0.98 |
| 50 | 4.8 | 1.02 |
| 100 | 5 | 1.03 |
| 200 | 5.5 | 1.00 |
| 400 | 6.5 | 1.01 |
| 1000 | 9.3 | 0.99 |
I can't think of anything that could cause this anomoly at 5Hz. Is there something in the software that I don't understand?
Any help is greatly appreciated.
