After referring to your new liquid exchange model from the link below, I may encounter difficulty understanding the mechanism and wish to discuss it with your experts.
https://community.altair.com/community/en/edem-api-contact-model-example-liquid-exchange-model?id=kb_article&sysparm_article=KB0124628
I am assuming that the simulation involves a purely particle-based system without the presence of a physical liquid phase, and the particles are thought to be coated with an imaginary liquid membrane, leading to the cohesion behaviors between particle interactions. In the simulation configurations, let's assume that the liquid content is 10%, so every particle will be evenly coated with a thin binder liquid layer. When the liquid bridge ruptures, the liquid content on each particle is assumed to remain at its initial value. Could you kindly clarify the mechanism behind the observed liquid exchange phenomenon under these conditions? Additionally, if liquid exchange does occur, what would be the appropriate method to export and quantify the amount of transferred liquid for further analysis?
Thanks for your great help in advance.
Best Regards,
Yu
