I would like to perform a CFD topology optimization. In order for the results to converge faster, according to support it is advisable to first perform a topology optimization at low velocity (already done) and then use the result as initial design topology for the second optimization run with higher inlet velocity.
To do this, I now introduce a velocity ramp up, starting with the velocity of the first optimization run and going up to the target velocity (see image).
My question:
Where do I have to increase the time steps in order to completely run through the piecewise linear velocity progression (prevent the calculation from aborting before reaching the maximum inlet velocity due to reaching the convergence criterion).
1. in the flow solution via the “maximum no. of time steps”, or
2. in the optimization via the “minimum no. of design iterations”
As the simulation takes a long time, I don't want to have to test it first.
Many thanks and best regards,
Torben
