Hi all,
I would like to perform a modal analysis for a simple pole supported by preloaded cables.
For the cable behavior, a possible solution is to consider the CGAP elements. However, I couldn't consider this option for the linear modal analysis due to the non-linearity of the CGAP.
To better explain the test case I have attached a simple scheme of the problem.
Is there any solution to solve this problem?
Thanks in advance
Regards
