Dear Forum Members,
I hope this message finds you all well. I am currently working on utilizing the LOAD/PBLAST card from Radioss for Air Blast-related applications. During my exploration, I have encountered some doubts and questions regarding this card. I would greatly appreciate it if you could provide some insights or clarification on the following points:
In the experimental data of /PBLAST the unit system {cm, g, µs} is used. Should we define the problem using this specific cm, g, µs system, or are there other unit systems that can be used?
It appears that extracting the pressure output on the applied surface is not possible using this card. How can we validate the external force evaluated on the area?
In the context of validating the Air pressure developed on the surface, which formulation or methodology is commonly employed?
If any of you have validation data, examples, or any information related to the above queries, I would be grateful if you could share it. Your contributions would greatly assist me in my project.
Thank you in advance for your time and support.
Best regards,
Sachin
