I am trying to simulate a composite crash structure in radioss.
This is my first project in RADIOSS and so I am not well versed.
Initially, I was looking into the monolithic structure and so I used M25_COMPSH for material definition and P17_STACK as property for my component (Laminate STACK and ply P19_PLY). I was successfully able to simulate this.
Later I wanted to run the same analysis as a Sandwich panel. I defined a honeycomb using the M28_HONEYCOMB material law. But I do not understand how I can integrate the honeycomb into the stack.
I also tried to study P11_SANDW as an alternative property but again I failed to understand how to integrate it into the model.
Some guidance with this will be really helpful.
Thank you.
