Optistruct Convergence Settings
exx077
exx077 Altair Community Member
I am running a topology optimisation using Optistruct. The results I am getting for a standard min. compliance, constrained volume fraction run without any manufacturing constraints are invalid. The simulation runs but the results do not show any clear structural members but mostly very low density material.
However, when I use minimum member size control, extrusion constraints and change the discrete value the results achieved are valid (show structural members).
Is there a way to chance the minimum convergence parameters to encourage the solution to find a valid structure for on optimisation without manufacturing constraints.
Thank you in advance
Welcome!
  • Altair Forum User
    Altair Forum User
    edited April 2018
    Hi @exx077
    Usually, results without manufacturing constraints are best results but not manufacturable.
    Did you try to change the ISO value in HyperView?
    Is it possible to share the model file?
  • exx077
    edited April 2018
    Hi @Prakash Pagadala,
    I have had a look at the iso result on Hyperview. This is how I can tell there is lots of low density material (<0.05). There are only 8 iterations, which is what makes me think that there may be insufficient convergence.
    Density>0.05 for VF=0.05 (left) and 0.075 (right)
    <?xml version="1.0" encoding="UTF-8"?>density0_05.thumb.jpg.3e9256b4ef3778df249184e690590199.jpg
    Density>0.1 for VF=0.05 (left) and 0.075 (right)
    <?xml version="1.0" encoding="UTF-8"?>density0.1.thumb.jpg.56f67cdaf1db9cea1f7004badbf441a4.jpg
    HM file:
    des.H3D file:
    Thank you
  • Altair Forum User
    Altair Forum User
    edited April 2018
    PFA results
  • exx077
    edited April 2018
    Wow, these results look great!
    However, I do not understand what they are showing.
    Does PFA stand for Progressive Failure Analysis?
    If so, do the regions or high density show where probability of failure is highest?
    Thanks
  • Altair Forum User
    Altair Forum User
    edited April 2018
    PFA( Please find attached results)
    The results show optimal material layout. Red being the highest material density.
  • exx077
    edited April 2018
    @Prakash Pagadala,
    I see, thank you.
    What optimisation parameters have you used?
    The square panel regions are really impressive.
    Thanks
  • Altair Forum User
    Altair Forum User
    edited April 2018
    I will share the model with you
  • exx077
    edited April 2018
    Great, thanks again @Prakash Pagadala
Welcome!
Welcome!
