Altair RISE
Nominate Yourself Now!
Is it possible to set the separation force?
User: "Mark Lin"
Altair Community Member
Updated by Mark Lin
Hi all
As the title, I want know that if I can set a separation force between any contact surface.
In other ward, the contact surface be separated after bear a specific traction force.
I was tried to apply a normal force at the contact surface in first LoadStep, and the traction force will separate the contact surface in second LoadStep.
But in this case, my modal generated stress in first LoadStep, and I don't want this stress before I apply the traction force.
Can someone give me any suggestion?
1 - 3 of 31
    User: "Gildas_GUILLY"
    Updated by Gildas_GUILLY
    Hello Mark,
    What is the physical reason why the contact  would not open with light force ?
    - Is there something at the interface providing the unbonding (adhesive, glue...) ?
    If so, are you aware that modelling of "Cohesive zones" are available in OptiStruct ? You can use cohesive elements or cohesive contacts to model the damage to a bonding interface.
    - Is is due to some kind of preload ? (atmospheric pressure)
    If so using a preloading loadstep would be the option, but as you mensionned you will of course get resulting stresses I you would have in reallity.
    Gildas
    User: "Mark Lin"
    OP
    Updated by Mark Lin
    Hello Mark,
    Gildas
    Hi Gildas Guilly, thanks for your reply
    Yes, That is similar to glue, thus I tried the cohesive contacts.
    But the cohesive contact is difficult to converge.
    Actually, I don't even know that if is the setting make sense, especially DMGEVO
    Are there any example?
    Hello Mark,
    I jointed an example using cohesive interface.
    You can also loo at the knowledge base. There is a documents giving some ideas (KB0037668).
    Gildas
