I´m applying an acceleration of 5 g on my model, which is made out of very thin CFRP layers. I´ve created middle surfaces of my model and then meshed it in 2D. The final displacement Optistruct shows me, are around 1,6E+10 mm, which is totally unrealistic. Even when I create thicker layers, the results change only incrementaly and the displacement even gets higher?! When I do the same calculations on a simplet plate, the results are also high (due to the very thin plate), but are roughly correct.
Where could be my error? Or is my model just not correct?
