I have a problem with size optimization of a composite shell. In a nutshell, I notice that the global mass (objective function to minimise) increases even when all constraints are satisfied, so the optimization ends with non optimal solution (see pictures). Why?
I want specify that I also performed the same optimization with less stringent convergence criterion and in that case the problem doesn't occur. In my opinion it is very strange. What am I doing wrong?
The model has only two loadcases and three constraints. The objective is the minimization of mass.
