Hi Everyone,
I just found out that Optistruct now have a possibility to run explicit Simulation like this Tutorial (OS-T: 7000 Phone Drop Test Analysis) (https://2021.help.altair.com/2021/hwsolvers/os/topics/solvers/os/phone_drop_test_analysis_tutorial_r.htm#reference_vgr_whz_jkb)
I already done the tutorial and now i want to try something slightly different. I would like to constrained the phone in all DOF, an let the rigid wall (Rigid body in case the rigid component not a planar surface) fall with a predefined velocity in a curve.
I try the same way with TIC(V) like in the example but it still not working. I try to define Rigid body (RBE2) and it also still not working.
Can somebody help me how to assign the velocity to the rigid body?
Thank you in advance
Best regards,
