hi friend,
I am trying to make a bottom crash analysis, but after radioss finished, I find that the spot didn't work, the components that should be weld together directly broke, I create it in 1D - connectors - spot , and I choose the spot type is type2 spring. could you help to figure out where is wrong? I attached the math as attachment.
thank you,
Heng Gao
