In a 2D axisymmetric analysis I get the following error: "Error 6523 - Negative basic x coordinate (GRID 3) is illegal". But no geometry is defined in negative X in my model.
What could be the cause, and how to solve that?
Tutorial OS-T 1394 was used for comparison; if I use the initial file "Ball_Joint_2D_Axisymmetry.hm" then everything is fine but if I start from scratch, this error keeps popping up? So it looks like I missed something. I tried both the XY and XZ system.
