This is a mesh refinement from Trelis. Is it possible to do this in Hypermesh (auto or manual)? If so, how?
Thanks
trelis.ts
Could you share this mesh?
Unfortunately I don't have this mesh because I don't have Trelis. Here's the link to the image I posted:
https://cubit.sandia.gov/public/14.0/help_manual/WebHelp/mesh_generation/mesh_modification/mesh_refinement.htm#drawing
I wonder why HM doesn't have this ability for hexamesh (or it has and I'm missing it)!! This hexa mesh makes much more sense compare to the automated tetramesh in HM!
It's interesting your picture. But I would like to see inside of the mesh /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Yup me too! I wish we had its file. It would be awesome to back track it and make it with HM /emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
Gonna ask around to see if anyone has/used Trelis and let you know if I got my hand on that mesh.
Thanks to @maysam
the mesh looks very impressive
this is sample (copy/move this block to construct bigger model)
Cool ! Thank you @tinh !
The same method, but for '1-to-2' splitting.
Nice! I was also working on different alternatives... I got this:
Quick question... in the original Trelis model, they used those elements that I enclosed with red lines (see screenshot 1) but in the mesh that I made in HM (screenshot 2), I didn't put them and still gave me a pretty nice transitional mesh (at least it passed all the element checks). Do you think those layers are necessary? I haven't run the model in any way and just wondering!
Its good to keep one layer like this because drastically changing element size will lead in to poor results.So for better results keeping one layer like this is good.
Regards
Rahul R
Nice! I was also working on different alternatives... I got this: <?xml version="1.0" encoding="UTF-8"?>
Cool! Could you share the mesh?
Here's my test for 1-2 splitting
Thanks, here's mine. I made this using split (shift+F6) but the problem is in HM13 it only works one element at a time (in one direction each time). Hopefully in later versions of HM, they make it work for multiple elements.
Thank you @maysam
Here's my script to create this splitted elements. My script can run for several elements but the script pays no attention to connectivity between elements.
Great! Thanks @Q.NGUYEN-DAI for sharing the script. I'm still learning tcl and was kinda struggling to do what you did this fast /emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
Any recommendation about learning tcl would be greatly appreciated!
There're a lot of tutorials about TCL on the net /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Using Hyperworks without TCL is just 50% of software only /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
There're a lot of tutorials about TCL on the net /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> Using Hyperworks without TCL is just 50% of software only /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
So true!
So is this possible on hypermesh now? I cannot see that it is
Hi All,
I am new to Hypermesh, I needed to refine my mesh by splitting the elements just like few images shown here. I have been able to do it with 2D shell elements. But I would like to create transition mesh in 3D directions. As of now, (attached picture) I am able to refine on the front surface of the cube and then either use element offset or drag to create a solid mesh with hex8 elements. I would like to create a similar mesh transition on the top and left surfaces, as well as ensure there is mesh transition from fine to coarse in the interior elements. Could anyone let me know how to achieve it?
Not sure can help, but maybe can give you some ideas.
Model:
Another method:
