Hi Peri Raghu Vamsi,
the solution for your problem is already given in the error message
*** ERROR # 3413 *** DDM is not supported for heat transfer analysis with more than one processors. Please resubmit job as smp or ddm with one core.
So I would recommend to use -nt 4 only in this case. = SMP run
In case you have enough license units available, you may want to increase the number.
