Dear Engineer.
 I will first perform a modal analysis on a pair of gears with prestressing to obtain the modal frequencies. Then calculate the resonance velocity manually.
How can I get the stress distribution map of the gears at the resonance speed? Is this possible in motionview or Hyperworks? Or which module is recommended to analyze at resonance speed to see the stresses generated by resonance.
Also is it possible to create a contact relationship between a flexible body and a rigid body or a flexible body and a flexible body in motionview? I see that you can only create 3D rigid to rigid or 2D rigid to rigid, is that correct?
