I am using AMS for the attached rad files. I have uploaded my results and models for reference. I had help in this thread previously to reduce time step:
https://community.altair.com/community?id=community_question&sys_id=125648f61b2bd0908017dc61ec4bcb7a
Here has been my process so far:
In Test3, I ran the solver without any AMS, and the mesh was poorly optimized. My total run time was about 30 min, and my maximum displacement was 0.15 m. This is a ridiculously high result, as it can't be possible to have a deformation of 15 cm. I tried to add more accuracy by increasing the number of SPH nodes, however the run time was over 60,000 seconds.
I was advised in the attached thread to get rid of any elements with bad aspect ratios etc. I did so and created Test4. Note, I had to used RBODYs for certain parts of the mesh as it was the only way to get rid of the bad aspect ratios entirely. At that point, I was able to almost triple the amount of SPH node, however it was even less accurate than before, with a max deformation of 18 cm. It also takes about an hour to run - double the time.
I don't understand, seeing as the time step was reduced by at least one order of magnitude between the two iterations. I have more nodes, it takes longer to run, yet is somehow less accurate. When I try to use AMS, the simulation run time is either not decreased significantly, or results in the simulation being killed for exceeding the mass and energy error.
Can anyone please advise what is wrong with my model? I suspect it may be the RBODYs, but I'm not sure.
Thanks in advance,
Ayman
EDIT: I know it is not accurate because I ran it with very few SPH nodes, and got a deformation of 0.25 m (25 cm), which is almost double what I got with what I have in Test3.
EDIT2: Attached Test6. That is my solver with AMS enabled.
