Seek help about EDEM!!
 I set up particle solids density 100,000 kg/m^3 at first when generating particles. After generating all particles, I'd like to modify solids density to 2,700 kg/m^3. However, unfortunately, it seems it cannot influence the generated particles. Their density is still 100,000 kg/m^3 without any change. So, once a particle has been generated, its properties seem cannot be changed anymore.
 Is there anybody have an idea that can modify solids density of generated particles?
 Thanks a lot,
 Henry
