Buen Día.
Pido su apoyo para entender cómo interpretar el resultado de Inspire Extrude Metal, en la parte de Extrusion, el resultado "Flow Stress"
Flow stress is the stress for the given strain, strain rate, and temperature to sustain and continue to viscoplastically deform the material. It is a scalar value. It is used to define material behavior.
Hi there,
Depending on what is the material of the die; the stress shown in the referred picture lets you know how much mechanical force the die is being exposed to during the extrusion. When you compare the von misses from the figure to the stress-strain curve of the material, you can be able to tell if the mechanical force is enough to produce elastic deformation, plastic deformation or breaking of the die.
Hope this comment helps!
