We're running into a problem with installing 2022.1 on all of our machines (various versions of Windows and types of workstations) with the following error:
Flexeraaxd$aaa: C:\[user path redacted]\AppData\Local\Temp\I1662736769\Windows_Pure_64_Bit\resource\iawin32.dll not found
at Flexeraaxd.af(Unknown Source)
at Flexeraaxd.aa(Unknown Source)
at com.zerog.ia.installer.LifeCycleManager.init(Unknown Source)
at com.zerog.ia.installer.LifeCycleManager.executeApplication(Unknown Source)
at com.zerog.ia.installer.Main.main(Unknown Source)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at com.zerog.lax.LAX.launch(Unknown Source)
at com.zerog.lax.LAX.main(Unknown Source)
2022.0 installs just fine, but none of the 2022.1 versions, being Simlab or HW install properly and all fail with the same issue...
