I am trying to run a modal analysis on this component but at the regions marked there is a connectivity issue. Can someone hep me rectifying this
Hi
it seems that the beams that are reaching the vertical beams are not connected to the nodes.
E.g., in order to the 3 beams in the node id 3018 connect to the vertical beam, it has to be merged to the id 432, or have another CBEAM connecting them.
Same to the right side region you indicated in your image.
I hope this is helpful
Regards
