Hello Altair community ,
 I hope this message finds you well. I am currently working on simulating an aluminum bar with following dimensions: radius=5.642mm and length=200mm (see attachment 1). The simulation is conducted in Flux 3d, using magneto harmonic application, with a low voltage 2v ,50Hz (see attachment 2).
 However, l am facing an issue with the inductance calculation regardless the method used the (energy, or impedance..),the calculated the inductance value consistently remains at 0.12uh, which is lower than the expected exact value is 0.14uh, despite mes efforts, I have been unable to optimize the simulation further.
 I am reaching out to the Altair community in the hope that someone  with expertise in electromagnetic simulation can provide assistance or validation of for this model. I am in a times sensitive situation and any guidance or validation would be greatly appreciated.
 Thank you very mush for  your time and consideration.
 Sincerely
 Sam
