hi,
i need to add two separate odb file of different loading for n number of cycles ...
Radial force of ± 35 kN and in torsion direction to be applied simultaneously in phase with both loading to be applied at 1 Hz in sinusoidal manner for 3 lac 20 thousand cycles
can i make single deck and apply for constant amplitude for -1 to 1N for 1 sec image for load cycle is attached
