Hi all experts,
I'm dealing with hyperelastic material models and I'm really stuck in this. I have some questions, hope you guy can help me.
1. What is the difference between Uniaxial test versus Planar test?
2. Why do we need to calibrate hyperelastic material model? What happen if I only use curve data (uniaxial, biaxial, planar) or only use hyperelastic material model's parameters? Which is more accurate?
3. When I do a curve fiting test (example on ABOYCE model, Uniaxial curve data), then OptiStruct give me these coefficient in out file:
So, how can I deal with these coefficients? Are these parameters use for next simulation without curve data?
4. What is homogenous deformation? Is it good or bad for calibrating hyperelastic material?
Thanks all.
