Hello all!
I am currently experiencing the following issue with Radioss:
In my model, there is a rigid plane that I want to rotate around a given point in a given direction. For this purpose, I have set up a SKEW/MOV in that point. The origin node coincides with this point. Here is an image of how I've set up the system (with respect to the global one):
The plane is subject to IMPVEL load (with respect to the same SKEW), where I specify a constant velocity in rad/s, in the YY direction (i want it to rotate around the Y axis of my skew).
The problem is that when I check the results in HyperView, I can see that the Z and Y axes have switched. which means that the plane is now rotating in the completely wrong direction.
In addition to that, it seems like it is rotating around a completely different point, instead of around the origin of the SKEW system.
If anyone knows how I can solve this or why I am encountering this problem, please let me know! All answers are much appreciated.
Thanks!
