MAT9OR SYSSETTING
Martina Blazheska
Martina Blazheska Altair Community Member
edited January 2024 in Community Q&A
Hello everyone,
I am trying to model an orthotropic material using the MAT9OR card.
From the Help page for this material card, I can see that NU31 can be interpreted as NU13, through the SYSSETTING.
I tried to create a SYSSETTING card to switch the NU31 field to NU13, however, I cannot find the correct option to choose:
I referred back to the Help page for SYSSETTING, where MAT9OR is indeed listed as an option:
I just cannot find it in my interface.
If anyone knows what I'm doing wrong, please let me know.
Thanks,
Martina
  • Sriramanuj_16
    Sriramanuj_16
    edited January 2024
    Hi Martina,
    Currently, the capability to visualize in HyperWorks under the system settings option is not accessible. However, the solver does support this functionality. Therefore, you can simply insert SYSSETTING(MAT9ORT=NU31) into your file, depending on your preference for NU13 or NU31, and proceed with running the analysis. Attached is the file for your reference. Also, you can see the message in the .out file below.
     NOTE # 2380
     SYSSETTING(MAT9ORT=NU13) is defined, causing the 8th field on MAT9ORT
     cards to be interpreted as NU13 instead of the default NU31.
    Let me know if this works for you.
    Sriramanuj Prabhu.
