I was wondering if it's possible to generate hollow particles or shapes, rather than just solid spheres. Specifically, I would like to generate thousands of hollow cubes in the same way angular or spherical particles are generated. The attached figure shows an example of the desired shape. I also have an STL file ready for upload, which I assume will be necessary.
Thank you for your time and consideration
