HelloI have a signal (upper waveform), I want to reduce its frequency by 512 times so that the lower waveform is formed, how can I do this?
Hi, Reza,
This question is related to your algorithm design, not related to how to use PSIM. It would be more effective for you to discuss such questions with your colleagues.
Your description of the question is "I want to reduce its frequency by 512 times".
The simplest way is to use an up/down counter feeding to a comparator. Using the 1st signal as the clock input.
You might have other considerations due to system control requirements.
