Hi everyone,
 I'de like to recreate a realistic cilndric hinge without 0D elems.
The exercise I'm attempting to do is down below. The hinge is on the left corner.
 - I've created a contact surface
 - I did set Clearance to 0 because of the gap between the red comp and the yellow one.
The PROBLEM is: the yellow comp doesn't slide on the red one. I wanted to permit a rotation on the z-axis but it's like they are stuck together.
 Could someone help me?
I'm attaching the HM file and the out one.
 Thank you
