Hi there,
I want to run a Feko simulation that would produce *.efe and *.hfe files, but I don't want the Feko windows to be visible (in my case, Feko is used as an "invisible" electromagnetic simulator, called by a *.lua script from third party software).
For example, I've written a simple *.lua script that just creates a wire antenna with a near-field point request.
I get the *.efe/*.hfe files that I need when I run the command line script as follows :
cadfeko --run-script "Your path"\Test.lua
But if I run the same script with the non-interactive command :
cadfeko --non-interactive --run-script "Your path"\Test.lua
then the *.efe/*.hfe files are not created.
Is the non-interactive mode supposed to produce no files (so what's the point?) and is there then a way to get the *.efe/*.hfe files without seeing CADFeko windows running?
Thanks in advance if anyone has any ideas.
