i have issues "running" my model in MotionView. It seems that it does not create the h3d file (although this is checked under Output Settings). Trying to Animate it I get the message "The animation file xxx.h3d has not been found. It was not generated or has been removed"
The Log says only:
*** Begin sending off data
Reading API version string [2021.0]...
Writing model to [D:\\Test_3.xml]...
*** End sending off data
I guess my MotionSolver is not appropriately installed. Trying to open the linkage "MotionSolve SubRoutine Builder 2021" it says "An installation of Visual Studio was not found on your System!". Could that be the issue?
Also I installed all Altair Products on Drive D while Visual Studio is oviously installed on Drive C. But this should not have any effect.
Is there a way to check if the MotionSolve SubRoutine is properly connected to MotionView?
Any help highly appricated. Best regards,
Mrage
