Question on how to apply pressure?
Mohd Azhan Fikry
Mohd Azhan Fikry Altair Community Member
edited June 2022 in Community Q&A
I am currently trying to simulate a pipe burst test simulation. The model will simulate pressure being applied to the inner wall of the pipe. The condition is that the pressure applied must increase linearly with time which is 60 kPa/s. I have checked all types of PLOAD that can be used but it seems there is no PLOAD that can be used as mentioned in the condition "pressure applied must increases linearly with time". Is there any way that I can apply pressure as per mentioned in the condition? Appreciate any help.
Thank you.
Best Answer
  • Alihan Alayoğlu_22549
    Alihan Alayoğlu_22549 Altair Community Member
    edited June 2022 Answer ✓
    Hello, I would like to ask another question, for the step "Create pressure load on a load collector w no card image" how much pressure do i need to define? Do i define 0 MPa in the pressure as my pressure at zero seconds is 0 or do i define any value of pressure? Appreciate any help.
    It depends on your problem. For example; you could create 10 bar pressure and define the table such this: (x=time , y=pressure ratio)
       x - y
       0 - 0       (0x10=0 bar pressure at 0 second)
       1 - 0.1    (0.1x10=1 bar pressure at 1 second)
    2.6 - 1       (1x10=10 bar pressure at 2.6 second)
       3 - 0.5    (0.5x10=5 bar pressure at 3 second)
    3.3 - 5.6    (5.6x10=56 bar pressure at 5.6 second)
    and you are able to switch between lineer and log scales for tabled1 card image in both x and y axis, individually.
    I hope it helps and please don't forget to highlight as correct answer :)
    edited June 2022
    If there isn't any non-linearity in your system; you could use direct transient analysis procedure.
    Define time vs load values in a TABLED1 load collector
    Create TLOAD1 collector and select pressure load as exciteid and TABLED1 for TID to set the time dependency
    Create TSTEP load collector to define time step (i.e. 300 time step (N) and 0.01 increment (DT) for a 3 sec total time )
    Select TLOAD1 for DLOAD and TSTEP for TSTEP (time) in Transient (direct) load step
    Please check this e-book https://altairuniversity.com/free-ebook-learn-dynamic-analysis-with-altair-optistruct/ out for more.
  • Mohd Azhan Fikry
    edited June 2022
    Thank you for the suggestion. What if there is non-linearity in my system? Such as non-linearity in my materials.
    edited June 2022
    Set analysis type as non-lineer transient and add NLOUT load collector, differently. Depending on your model and solver version; you could add param card and activate LGDISP=1 if needed.
  • Mohd Azhan Fikry
    edited June 2022
    Thank you for the guide. Before that, does this fall under dynamic analysis or static analysis? I am new to this so I am still confused about certain things.
    edited June 2022
    Transient means that there are changes in your system with respect to the time. This takes the dynamic effects like inertia and damping into account. Thus your analysis becomes dynamic. Read this for more;
    https://feaforall.com/how-to-get-started-with-transient-fea-simulation/
    https://www.youtube.com/watch?v=QdShij33teQ&t=1s
    I offer you to read Altair's e-books starting with the practical aspect of FE simulation. These will enlarge your perspective to the FEA world.
    https://altairuniversity.com/free-ebooks/
    All we were on the same road in the past. Please dont worry and keep going to ask.
  • Mohd Azhan Fikry
    edited June 2022
    Thank you for the advice and help
  • Mohd Azhan Fikry
    edited June 2022
       x - y
  • Mohd Azhan Fikry
    edited June 2022
       x - y
    Thank you for the guidance and help.
