Error during 3D bolt pretensioning
I get an error while defining 3D bolt pre-tensioning using the Pretension Manager. After selecting the elements and defining the boundary nodes, I get an error "The selected nodes did not define any faces". Any idea what could be the reason?
Thanks.
/Shivanand
Hi
there is this tutorial
OS-T: 1390 Pretensioned Bolt Analysis of an IC Engine Cylinder Head, Gasket and Engine Block System
Do you face similar problem when attempting to work on the tutorial steps?
Regards
0 -
Hi Rogerio,
I looked at the tutorial and followed the same procedure. But I haven't tried the tutorial as is. Maybe I could try that.
Thanks.
0 -
Shiv_21125 said:
Hi Rogerio,
Thanks.
this error is probably related to the creation of the pretension cut, which is a sruface from a face of the bolt.
you need to select a layer of solid elements, and then define 3nodes from the same element to pick a face. Or just use the 'face' selection on creating the surface.
