Hi everyone,
I tried to do a topology optimization of a piece made of one design and two non-design areas. I want this body to reach knew mass, inertia yy and x coordinate of cog (enter certain tolerances).
The simulation runs successfully, but in the design area there is a non continuity of material as you can see in figure attached, so a part of the piece it's fluctuating in void.
Any idea for create continuity of material? I tried to set mindim and maxdim in desvar paramter, but no results. Maybe the design area was too large, so I can reduce it to force the creation of continuity, but I think this isn't the most elegant method... I attach also the .fem if you want to look it
Thanks
