Hi.
I would like to visually analyze bonded particles passing through the clipping plane of a translating geometry.To do this, I would like to adjust the position of the clipping plane according to the movement of the geometry.
Thank you.
Hi Shinichiro,You can create a geometry bin and link the position of that bin to the position of your geometry, so the bin will follow the geometry's motionBest regards,Renan
Hi Renan,
Thank you for the Answer.
I was able to perform the desired operation by using geometry bin.
Best regards,
Shinichiro
