Press fit simulation of 2D 1/6 Stator Model Constraints?
Junhyeong Kang
Junhyeong Kang Altair Community Member
edited November 2023 in Community Q&A
hey all, im trying to do press fit Simulation of 2D Stator Model due to Housing. now im thinking about giving Constraints to Stator on 0 Degree and 60 Degree Face edges. But i m not sure which DOF should be 0 and which not. can you guys give me some Idea?
bellow u can see the 2D model i designed. Thanks in Advance
  • Wesley_Peijnenburg2
    Wesley_Peijnenburg2 Altair Community Member
    Is the coordinate system set as cylinderical with Z as axis direction? If not, you can find more info in this forum answer.
    Then, you can constrain the second DOF to 0 (restrict tangential movement) on both sides.
    Hope this helps!
    - Wesley
