I have ran a non-linear static analysis.
My load application is outward pressure, and I am specifying my incremental output parameter as TIME set.
Is there a way to know, or what Global Output Request Card I should select to find out which level of increamental output correspond to the level of pressure.
Let says the pressure I define is 20 psi.
https://community.altair.com/community/en/nlout-definition-with-nonlinear-incremental-output-parameters?id=kb_article&sysparm_article=KB0117579
Thanks,
Jerome.
I am not sure if i fully understand, but do yo know OLOAD?
Hi Loisf,
Thanks for helping.
I have try to export OLOAD in my model, and I see now my analysis result have the applied force (mag) and moment. Please explain to me what the countour plot means?
I am trying to figure out output interval 0.8, what is the pressure exerted on the model inner wall.
As right now, I am running non-linear static analysis with define 20psi on the model inner wall, and I have specifying to use Hashin failure criterion.
If I say the failure index pass 1 at 0.8 output interval, can we says that the model is breaking at 0.8*20psi, which is 16psi is the failure pressure for this model?
Best regards, Jerome.
