hi,I have been doing a simple simulation recently, the material is nonlinear, so the loadstep is set to nonlinear quasi-static analysis, but there is no error when applying a uniform load of 50KN, and there is a mistake when changing to 100KN uniform load.
*** ERROR # 4965 ***
Maximum number of time increment cutbacks reached,
analysis aborted.
*** Nonlinear solution failed to converge for Subcase 1 ***
I don't know how to solve it,could you give some advices?
here is .out file. thank you.
