I've attempted to create a model which optimizes the tower of a wind turbine subject to the weight of the nacelle, hub and blades. I'm running the sim and getting Error #312 - In static load case 1 the compliance is negative or large 1.30949e+014. Optimization/buckling analysis cannot be performed. due to possible rigid body mode.
FEASIBLE DESIGN (ALL CONSTRAINTS SATISFIED).
The Max xDisp is massive and I've tested the tower by itself and it doesn't have any issues. I believe I've not correctly set up the contact between the hub, nacelle, and tower, but I cannot for the life of me find what I've done wrong. I've attached the file. Any help would be much appreciated.
