I have Followed all the processes mentioned in the 'License Application Process PDF' & respective video for the same, even though its showing some Error Code - 6 , what are the reasons & how to fix them?
Hello All,
Error code 6 is typically the below following issues –
· Typo in the license file name. Normal typos are: Altair is spelled wrong or file name is called altair_lic.dat.dat
· Location of the altair_lic.dat file is not in the security directory.
· Modification of installation directory location after the product was installed
So kindly try with the above options & once your problem solved then update us regarding the same
