I have a problem
/emoticons/default_wacko.png' alt=':wacko:'>...
when I run a file from the local network Hyperworks takes to open the file over 40 minutes (the files are 200 or 300), but if I open the same file from my computer took less than two minutes.
The local network is not the problem. I can copy files of 4GB in less than 4 m minutes.
Origne and using the same destination in all cases.
Thanks for all.
/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
