Here is an example circuit from the DC-DC folder that I've modified to add a resetting integral so that a cycle by cycle calculation of the switching and conduction losses can be seen.
The switch voltage and current is multiplied and then a resetting integrator is used. The integral is reset by the gating waveform on the rising edge.
I am using the level two MOSFET and I've added some lead inductance to model typically package inductance.
