Hello. I want to use Parameter Sweep Blook in PSIM 11.17, I follow the video about this in version 10, I did the same thing, but I dose not work, Is there anyone using Parameter Sweep in this version Please help me!Thanks
Hi Chantin,
What sort of variables are you trying to sweep? The use of the element should not have changed since v10.
I would recommend that you try scripting it is much more powerful and there are some resources in the examples\script folder. Also have a quick look at this tutorial video.
https://community.altair.com/community?id=kb_article_view&sysparm_article=KB0121284
Dear Albert Dunford
I try to sweep the switching frequency, The scripting is vey powerfll tool. i will try to use it. I did not know it before.Thanks for your support
