I want to connect my three phase Voltage Source Inverter to a rotary transformer, which is to be connected to a rotating diode bridge. Is it possible to use the resolver block for that? I see the resolver block has two stator windings, with each having positive and negative sinusoids, but I need three inputs-three outputs for my three phase system (to couple the stationary parts to the rotating ones). I didn't find my answer in the example provided by PSIM on the resolver. Any idea on how to simulate this rotary transformer in PSIM, or other rotary transformers having single phase input three phase output for example?
Appreciate your help!
