Hi all;
I keep working on a simulation coupling EDEM and Hyperworks CFD and I still have problems. I am doing a simulation of non-spherical particles and I have doubts with 3 parameters.
In the EDEM simulation I have used a scale factor x2 in the particles as specified here:
In Hyperwork CFD I don't know if I should put 2 or 0.5, because if I put 2 the simulation does not work.
Another question is whether, as is my case, I use a material with 6 different particles, in this section what diameter should I put?
Thanks
